audmod01
Well fellow Fisher Fans, you know how sometimes you keep missing the obvious? Today I discovered that I was doing just that when dealing with my own RK-20 remote control hand transmitter unit. I could not get the volume function to tune up even though I could get the channel function to tune to the volume frequency and operate the volume circuits in the remote control receiver. I finally realized that when the channel button is pushed you add capacitance to the existing capacitance of C27 which is a 280pFd 5% silver mica capacitor that is always in circuit across the transducer and its internal capacitance (whatever it happens to be).
Having to add capacitance to get the channel function to tune to the volume frequency with the adjustable inductor finally made me realize that I needed to add capacitance to that of C27 across the transducer to bring it into resonance at the volume frequency. I tried several capacitance values and finally settled at 110pFd across C27. With that amount of capacitance added, the inductor would tune the 41.805kHz frequency with a good solid high output AC voltage going into the transducer. I peaked the 41.805kHz output using the slug of the oscillator transformer while watching the detected signal at the base of Q4 in the receiver with my scope connected through a 470K ohm resistor to avoid loading down the base of the detector.. Then I tried the channel tune frequency and managed to peak its output at the 38.285kHz frequency while looking with the scope connected to the base of Q5 of the receiver. Now the RK-20 remote receiver responds to both channel and volume frequencies pretty much equally!
I also had to repair another broken trace, followed by changing the capacitor C28 which is a .05uF disc ceramic to the base of the oscillator transistor. This improved the symmetry of the oscillations of the circuit. I changed C29 from a .5uF electrolytic to a 0.47uF 100V metalized film polypropylene capacitor and the 250Hz modulation frequency began to work!
So now I have proved that the transducer will work for both channel and volume frequencies (with and without the 250Hz frequency which modulates the continuous wave frequencies for motor reverse) the 0.5mil metalized film that I bought to begin with. What a relief!!!
Now we know that a defective hand transmitter transducer can be successfully rebuilt and perform all the functions it was designed to do when new.
Joe
Having to add capacitance to get the channel function to tune to the volume frequency with the adjustable inductor finally made me realize that I needed to add capacitance to that of C27 across the transducer to bring it into resonance at the volume frequency. I tried several capacitance values and finally settled at 110pFd across C27. With that amount of capacitance added, the inductor would tune the 41.805kHz frequency with a good solid high output AC voltage going into the transducer. I peaked the 41.805kHz output using the slug of the oscillator transformer while watching the detected signal at the base of Q4 in the receiver with my scope connected through a 470K ohm resistor to avoid loading down the base of the detector.. Then I tried the channel tune frequency and managed to peak its output at the 38.285kHz frequency while looking with the scope connected to the base of Q5 of the receiver. Now the RK-20 remote receiver responds to both channel and volume frequencies pretty much equally!I also had to repair another broken trace, followed by changing the capacitor C28 which is a .05uF disc ceramic to the base of the oscillator transistor. This improved the symmetry of the oscillations of the circuit. I changed C29 from a .5uF electrolytic to a 0.47uF 100V metalized film polypropylene capacitor and the 250Hz modulation frequency began to work!
Joe
