audmod01
I have worked on building an Op Amp board to take the place of Q1, Q2 and M3 modular circuit portions of the RK-20 receiver front end. This has taken a number of days off and on since I am also working on installation of a 5.6KW solar panel system. Today I removed M3 along with Q1 and Q2 plus C1, a .47uF@10VDC. The R10 shown as a 4.7K ohm resistor inside M3 is actually an external resistor mounted on two metal pins above the circuit board. I don't know if the original M3 design including R10 proved to be a problem area and someone removed it as part of a repair or if it proved troublesome and the factory decided to mount a 1/2W resistor externally for better reliability.
I am lacking some 4.7K and 2.7K ohm resistors plus some more .1uF capacitors to complete the installation of the Op Amp sub-board, so those will get ordered from Mouser later today.
I will create a schematic of the dual Op Amp in Photoshop later today if possible and post it here. At present it consists of two inverting stages in series using 10K input resistors and variable 250K ohm multi-turn controls to adjust the gain of each stage. I suspect the maximum gain will not be needed and once overall gain of the two stages has been adjusted for the needed level of sensitivity and stability, I can use fixed resistors to handle the gain of each stage.
Here is a photo showing the receiver board prepared to receive the Op Amp board. It will use the existing -15VDC power supply in the unit in a manner similar to the Op Amp approach to implement a TL82 Op Amp and create a preamp output for the 500-C or 800-C receivers. The red lead will bring the -15 volts to the circuit and the black lead will be the positive ground connection.
You can see R10, the 4.7K ohm resistor along the bottom edge of the RK-20 PC board on pegs.
Joe
Joe
