I think the OP mentioned earlier that the problem occurs with and without the subwoofer being active.
With subwoofer off I mean Subwoofer amplifier is switched off. If he means that, than yes.
Yes, he has tried it with the subwoofer in the system as well as out, meaning he has it turned off or disconnected.....same difference.
Does the house have any mechanical systems which could be putting constant low frequency vibrations into the floor structure on a continuous basis? Is there some sort of factory or similar facility nearby that could produce subsonic vibrations affecting the house?
OP said the problem started a week or two ago. What changed (both in the house and in the surrounding environment) at that time?
One would hope it is same difference, but if his subwoofer amp puts out some sort of low frequency hum it is feasible that it could affect the TT even if disconnected.
Please remember that the OP took his entire system out of his house and moved it to another location, in which the problem persisted.
If there is not a consistent element in the mix, the OP has been cursed
First, it is only when the platter is moving that I’m getting the actual issue. I did a bunch of needle down tests with and without the record spinning and I can confirm that it is only when it’s spinning that the issue is present.
