tylerdurden
Your cabs came out beautifully!
My guess is that the larger box will improve the bass response somewhat, but not control the woofer excursion as well as the original, because the air spring is bigger, and thus more compliant.
Excursion factor has been a worry all a long. What I have found is how the woofer reacts (or com-plise) to the baffle. What I have noticed during crirical listening is a certain amount of chuffing congruant with the small woofer, I solved this by sealing the driver to the baffle and also dissolving internal "air spring" with my own dampening material as well as directional manipulation of air movement.
Given that they later released a ported version, you may be all right with that, but we'd have to know the woofer T/S parameters and run the box sims to be sure. Others here may have more of an intuitive feel for this from experience than me; I go by the numbers, basically....![]()
I think a ported design will add a certain amount of volume to the lower end, already achived by your new mod. The question then becomes < when is enough enough<
I am currently working on a 8" sub with 80 watts of power. I picked it up at Good will. A solid amp with a week cabinet. I am shooting for Upper threw low 20"s to start, then hopefully lower.
Hey you are the # man. I truely do admire the work.
