Hello. So, i saw locally a pair of Optimus Pro-X44AV which are basically the same as Minimus-7, but ported set. I thought it would be a great "cat-proof" set of speakers so i bought them for almost nothing.
Listened to them and i don't quite understand the hype of those Minimus/Optimus/rca miniature bookshelf speakers. I thought they sound saturated in the mid-high/highs or that frequency range has too much presence overall. So i opened up the speakers and realized that only the tweeter was filtered. The Minimus-7 mod here on AK could have been an option, but i wanted a really cheap mod for what i think is a really cheap set of speakers anyway. Salvaging parts if possible.. and the minimum amount of components possible to fill-in that already very small box.. So i went 1st-order, here is what i've done :
Only the coils that i needed to buy from Digikey. Here is the part list i used in case anyone is interested in trying the mod :
Per speaker :
-1x 680uH (226milli-ohm), digikey :
https://www.digikey.ca/en/products/detail/murata-power-solutions-inc/1468422C/5798129
-1x 3.6uF non-polar capacitor
-1x 3.3ohm 5watt (ceramic) resistor
The 3.6uF cap i used is a salvaged 3.3uF NP axial electrolytic 50volt, that i treated/reformed and that are measuring exactly 3.6uF (both of them).
The 3.3ohm 5watt i already had them. The range of the resistor that i would recommend is 2.7ohm (for a bit more high-end presence) to 3.9ohm (for a bit less presence).
It all fits nicely on the plastic backplate itself :
How it sounds? Way better. Well, its still a tiny speaker and won't do miracles, but is not weird sounding and all over the place in the mid-highs as it was before. It sounds.. more believable. So to me that fixed it!
Just a reminder in case someone would be interested in that modding option, 1st-order crossover is not filtering as fast. So do not drive them too hard to not put the tweeter at risk.
