Missing ma6100 volume pot
borke
Hi guys,
I have recentlly acquired an unfuncioning Mcintosh ma6100. I have dissasemblled the unit and it seems that the only thing wrong is that it’s missing the volume pot (apart the missing front glass). The problem is that i can’t find the volume pot anywhere on the internet. Is there any alternatives to the original McIntosh part or does anyone know where can i buy the original one. Thank you!
Best regards
Boris
Hi guys,
Best regards
Boris
The reproductions being sold at feebay (hifiaudio) and possibly others are garbage so don't look there.
Hello
The volume control on the MA6100 is also with the power ON-OFF switch and loudness tag
This is not the case with the MA6200 volume control
The value of MA6200 is 2x100K
The value of MA6100 is 2x700K
You understand now that using a volume control from MA6200 is not possible in MA6100
Here is a picture of the MA6100 volume control
Hello
Thank you for your information, im a noobie with that stuff, i’m learning along. Are there any potentiometery with the same agributes and values?
Older thread, but I want to share my experience with my MA6100 volume control issues. The original volume control was scratchy and had flat spots, so, I replaced with one from eBay and did a complete recap at the same time. It was a nice improvement and everything seemed fine for awhile. Then, one day I turned it on and the volume was about half way up at its lowest setting and a lot of hum started to appear. At $90 for that volume control, I was disappointed and cracked it back open.
Had seen the eBay volume control had mixed reviews. Volume does not kick in until around 9am, you have to solder on pigtails, cut the shaft and you have to use the original shield over the AC switch - which does not fit right. But it seems there are no other choices. The more I looked at it, that AC switch on the back of the volume control began to bug me. 120VAC running from the back right up to the pot where sensitive audio is adjusted did not seem to be a good idea to me. McIntosh went to great lengths to shield it, and I'm sure the original build worked fine 50 years ago, but given the eBay pot has so many kinks, it was suspect. I tried a quick test - unsoldered the AC switch wires, got them far away from the pot and wired them to always On. Plugged it in and 75% of the hum was gone. Yay.
So I left it that way - screw that power switch on the volume control. The wire is neatly tucked back where the power cable comes in and can be reconnected if someone wants to. Now, I simply use an external switch to turn power on/off And, since I no longer use the volume control power switch I was able to realign the knob so volume kicks in around 7am.
The other 25% of the hum and getting the pot back to pure zero volume was a bit more challenging. Short of waving a chicken over my head, these three things finally fixed it:
1. Reflowed solder joints and audio wire connections on the Volume / EQ board
2. Grounding is really quirky on this model - I re-tightened screws and the pot nuts on the volume control metal panel - this improved grounding and reduced hum.
3. Cleaned all pots and switches AGAIN.
This worked for me, short of taking it to a (getting harder to find) McIntosh tech. Your mileage may vary. I'm back in sonic nirvana with my MA6100 and Thorens TD150 with Shure Type III cartridge and Jico HE stylus (hey, not everyone has the budget to go total Gucci on this stuff! ;-)
Every once in awhile a tiny little gremlin noise will appear then vanish. But I only hear it when nothing is playing and it's not worth chasing for now. Other than that it's dead quiet. It's an old man just like me, and if my wife can live with my gremlin noises, than I can live with the ones on this very cool vintage preamp / amp.
Follow-up on my previous post: The gremlin noises got worse and volume on the eBay pot got wackier. After all this recap and new volume control work, I was really frustrated. Contacted Mark at Old Radio Parts (mentioned on this site) and he built me a dual 25% tap pot without the switch (for less $ than the eBay pot, I might add). Because of the scarcity of old parts, he could only make 1meg, but said it should be fine to replace the original 700K. The pot had long leads and soldered right in place, so it did not require making pig-tails like the eBay pot did.
After I swapped it out, I still had issues - really weird stuff that changed up when adjusting the COMP and MODE switches. I called him and he was extremely helpful. He said he's seen this many times, when customers suspect the new pot but sometimes it's a compound problem that had to be elsewhere. After listening to his advice, he was absolutely right!
Dove back into the unit and noticed the MODE SELECTOR was a mess - solder joints were awful and as I probed further, half the switch crumbled (old thin plastic) No way to replace that one but the only useful feature of that switch to me is Stereo to Mono - the rest is just superfluous. Many connections of critical audio getting flipped every which way by a weak 50-year old switch - not good. I bypassed the switch altogether and the gremlins noises disappeared! Then I was actually able to tie L&R back to the old switch where Stereo is switched to Mono, as luckily that portion still worked, noise free. The rest I can live without if it means no gremlins.
After all that, It still was not perfect. When I changed the 3-position COMP switch balance would shift and sometimes a channel would go out altogether when the volume was adjusted. D-oxed that switch again, but took my time and really got in there. And lo and behold, the gremlins are gone and that volume control and COMP selector now work perfectly. Finally!
I cannot say enough about the pot Mark built and his great support. Superb - USA parts - smooth, gradual, solid volume control. He can build one with the AC switch, but for me, avoiding having AC switched that close to the audio circuit and not having to worry about AC shielding makes sense. Also, it's great having the full sweep of volume without the switch.
So the lesson here is that volume control issues on these old MA6100's can be compound in many areas - controls, switches, grounding, solder joints - etc - something to consider before diving into a recap. I have never been happier with my MA6100 - it gives me daily listening pleasure and I can finally say it's trouble free.... for now!! LOL.
