Thanks. Did this
The beginning and the end of the plate recognizes, the rest of the movement is not for meDo you have the original mat? That one is blocking the record size sensors.
My browser blocked this as unsafe, but I did a little research on Yandex (Russian Google) and downloaded Once Upon a Time in the West. Sounds great! Nice gear BTW.
The line freq shouldn't matter, the power supply converts it to the DC that runs everything in the TT.I've had my faulty machine stored away for almost 2 years now as the repair guy is busy and there are other things going on in the world. I was doing some tidying and just decided to play around with it again. Beforei plugged it into my transformer I checked to see if it was 120 or 100v. I realised that it is 60hz, whereas I'm in a 50hz region. The platter speeds are correct but the problem (tracking error indicator is on, when you press Start, the arm moves to the beginning, arm goes down but once it hits the vinyl, the arm base assembly moves back to the right, dragging the tonearm with it.).
My question now is can these problems be related to the frequency mismatch please? If so, can it actually be made to work in my region without an expensive device to change the frequency?
Dunno, the power transformer and filter reservoir elyticaps should be rated for 50 cps supply, slightly heavier than for 60 cps. Then it can do both. Perhaps they only supplied the heavier parts in the TT, regardless of rating.Cheers. So my next question, is why not label it 50/60Hz LOL.
I have a LT-20, it is a great deck and must have both belts renewed for it to perform well. Mine works great but sadly the Silver Fascia Panel is in a poor state (Missing and chipped silver) This is not easy to repair. So Great performer but let down by it's looks.Hi,
If you are still around I would love some help please.
Just got one of these TT's. It comes on, the Left size light works, the platter will spin and lock the speed. When I press the Cue or Start buttons I hear a sound/noise. It sounds like a motor trying to do something so maybe it is the belt you were talking about. I can't easily see it but I assume that's what it is. I opened the bottom and I can see one motor with a small belt and that is intact. The arm does not move onto the record but if I move it myself it will slide left and right and if I place it on the record I can hear that it is playing.
Does this sound like the belt or was it 2 belts in the tone arm that needs replacing ???
I see the photos you posted but can't follow what is what.
I appreciate the help.
Thank you.
AJ
