Dear all,
I have been reading the fascinating post here. I am another Forte-II owner.
While I like the overall sound of the Forte-II, I do find there is a boxiness and muddiness in the mid-bass and bass region. This also gives a "slow" sensation in some music which has a lot mid-bass in the recordings. I have almost sent the Forte-Ii down the road until I got an Eico HF-81 one week ago and started to like the Forte-II more than before.
I would like to know if a new crossover upgrade such as those from Chris Munson or Bob Crites would address the problem I mentioned, especially the boxiness. I admit I don't have golden ears that are sensitive to subtle change in sound due to capacitor change in upstream components or speaker cabling change etc and that's why I have not been a fan of fancy and expensive cable rolling. I do hear a big difference of sound when my Eico HF-81 arrived and it totally transformed my Forte-II into a different speaker. Now I like the Forte-II but to want to know if spending a bit more on crossover can get rid of the muddy bass. etc.
Hope i can hear from the experience here
Welborne
First off let me welcome you to AK :thmbsp:
I haven't heard a pair of Forte II's some say they are close, and some say the Forte II's are a little forward. And there are some that prefer the Forte 1's I'm sure someone will chime in here!!!
There is much to talk about! Where to begin!:scratch2: Well lets take a look at the Forte II crossover schematic.
View attachment forte2.pdf
In contrast to the Forte I (posted on page 2 of this thread) the crossovers are very similar in design to each other other than values.
I fully endorse at least upgrading the caps at the very least. Due to as BEC points out increasingly high ESR values robing the music! And if you want more control IMO buy the biggest low frequency Air Core Inductors you can afford! I found the tweeters large inductor worth while also. and while I'm at it BEC's Auto Transformer for the mids was a serious improvement to! Read on...
Klipch's Web site says nominal impedance for a Forte I is 8 ohms but on my Terminal cup it says 4 ohm's nominal. The woofer is 4 ohms as I measured it. While the mid and tweeter are 8 ohm approx.
http://www.klipsch.com/products/details/forte.aspx
I also see we have different woofers I have the K-23
While the Forte II has the K-25-K which just might be 8 ohms?
http://www.klipsch.com/products/discontinued/details/forte-ii.aspx
If you have a Digital meter perhaps you can put it across the terminals and see if it really is 4 ohms or 8 ohms?
I found a little thread here
http://community.klipsch.com/forums/p/24443/24443.aspx
One thing you can try is running the Fortes on the 8 ohm tap instead of the 4 ohm or perhaps you already are! Which case try the 4 ohm. In which case if the woofer is 4 ohms and you were using the 8 ohm tap you might notice a bit more control and grunt!
In my case I was running on the 4 ohm tap and discovered that the 8 ohm was the ticket for me as the mids and top end developed greater body and had much more authority. I gave very little up in the bass in the way of body and dynamics. So the 8 ohm tap was a hands down winner to use.
Ok back to the crossovers!
After living with these very large North Creek Air Core Inductors for a few yrs now and having a friend with a stock pair of Fortes to A-B I am not a fan iron core inductors even though they appear to be more efficient and less costly. The large air cores that I have, exhibit control that seems to be that of an iron fist at least with my amps anyway. I haven't heard the Eico but I have seen its schematic and I liked what I saw in its power amp section. I can't rule out some of my transformer outputs control either at 28lbs of iron each.
I can tell you that the Forte I that I have is still playing bass lines that still surprise me and although they aren't perfect mine are amazingly taught and quick!
I use CD direct also, I once had a Peach II here which is very popular with Klipsch people. Unfortunately it was not to the level to the best that I have heard so I guess I'm spoiled. It is a fine preamp very musical. but when it was inserted I heard a distinct loss in transparency and that's a no,no for me. And the bass was very tubey and too loose to my taste.
So in the end I believe in the voicing of crossover components much like one chooses electronics. I found all of the parts where audible some good and some very bad! Pretty amazing.:yes:
So whether you go with K-stacks or BEC's you'll hear change. If you go the BEC route it may afford you the opportunity of some easy cap changes with the room that he has. Or you could put one together yourself.
One thing for sure, I'd get his Titanium tweeters for sure!
And last, I have never had so much enjoyment
And I've spent thousands more in the past.
SET12
