Jon S
I was able to contact China-Hi-Fi and they are sending me a free replacement bias board but I have to pay $25 for shipping which I am happy to do, otherwise I would have a dead amplifier.
I also just received another pair of Matsushita 6CA7 tubes. Like the first dozen I ordered a month ago (and which I returned), these tubes were tested by the seller as having high emissions of ~95%. Unfortunately, the measured plate current was again on the low side, 20 and 22 mA. Transconductance also measured on the low side, 4.50 and 4.46.
I can see why the tube reseller I mentioned earlier no longer handles Matsushita tubes, he said the used Matsushita 6CA7 tubes always test low. Maybe because the Matsushita tubes wear out faster? My final pair I ordered is coming in next week, they measured 50 and 54 on a TV7 tester per the seller. A passing measurement would be above 30. It would be interesting to see how these tubes measure up.
In the meantime, I took out my Muzishare X7 and am enjoying it since the Willsenton is out of commission. It has a quad of Psvane KT-88-Z Treasure Tubes (I've tried Gold Lion KT88s, Psvane KT88-T MKII and found the Treasures to be a bit better than the others) with an all Telefunken front end, 5AR4, 12AU7s and 12AX7s or a set of Psvane 12AU7/12AX7 tubes. TBH, the Muzishare sounds better than the Willsenton but I just did not care for the sound of the KT88 tube. It lacked the warmth and smoothness of the EL34. But when I used the Matsushita 6CA7s in the Willsenton, it surpassed the Muzishare. The only other time the Willsenton surpassed the Muzishare was when I used a quad of Mullard XF2 EL34s. The Matsushitas sounded almost as good as the Mullards if not as good.
