Bigmoonface
The $66 is just for shipping! So you either got really lucky BmWr75 and your customs missed the package or maybe you don't pay import duty??
Yep, I have no idea. My expectation was for the preamp to ship from Canada, but came from Hong Kong IIRC.The $66 is just for shipping! So you either got really lucky BmWr75 and your customs missed the package or maybe you don't pay import duty??
Bypass the preamp section in your amp using the direct RCA input.So before I begin any "rules of thumb" when connecting a pre-amp to a integrated amp!!? So my amp is a hybrid with tubes on the pre-amp stage and solid state on the output stage!! Now the amp has a "direct" rca input which bypasses the preamp stage! Would this be the optimal connection I should use!!??
Yes I know you'll say try the "direct" and through the amps pre-amp stage and see what you prefer (and I will) but "usually" would I bypass the pre-amp stage of my amp if a "direct" input exists!!??
Looks like you guys in the US don't pay extra import duties!! Rip off Britain is a little different costing me £118( $150)I paid the same as BmWr75, to Florida straight from China. No extra fees, DHL delivered in a week.
I like the matching cable ties on the caps, where did you buy the Toshiba tubes ? I am using two Teslas and a JJ.
Sounds great but I need spares.
Sadly because the original remote does not have a mute button I cannot teach the universal remote that.I got the same little remote, that one looks much better, dose the mute work by any chance.
Did you find it on Ebay also?
the example in the first image appear to be metalized film (too small in dia to be film and foil). May want to look for a film and foil but will not be cheap.I'm looking to purchase the MP 701 Mk3 preamp sometime this month.
Upgrade options on the pre-amp are ODAM reference caps made in the US for an extra $200. Standard caps are hovland caps made in Germany.
Is it worth upgrading those caps or should I just stick with the standard ones??
From this photo, it loos as though the board has been assembled using Dale RN60 film resistors.Rolled the tubes a few days ago to GE 5ar4 and JJ 6922, made a good improvement, but today I changed the caps to some Mundrof silver gold oil, and it's like a different preamp. Everything opened up, clear airy highs, wider stage, tight bass.
With just a couple hours on them, can't wait to hear what comes next.
