Hi,
Bought a MX110 3 weeks ago - I never turned it on - and I just finish recapping it.
I first started it with a Dim Bulb Tester and everyhting was working fine. Then went without. One of the 220ohm white resistor near the electric plugs started smoking (Pretty sure it is R152 - it is between the other 220 and the big browns one).
I recapped all 3 cans, all with single caps.
Recapped the 10uf and 12uf.
Recapped both 1uf at c106,107.
Replaced the selenium bridge with 4 SF4007 diodes.
Ordered a MF72-47D20 47ohm 3amp thermistor.
I read that I should put a resistor after the bridge. What value ? In serie between D11,12 and anode of c114 ?
Will/should it fixes my smoking resistor problem ? That resistor is measuring about 210, should I change it ?
Did some fast measurement, my line voltage is 117volt.
For the test point :
225volt > 254volt.
170volt > 199volt.
155volt > 172volt.
108volt > 120volt
83volt > 100volt
(I think I measured at the good place but do not want to turn it on again for now)
So it looks like I am pretty high.
btw my multimeter is true RMS
225volt > 254volt.
170volt > 199volt.
155volt > 172volt.
108volt > 120volt
83volt > 100volt
