My concern is with those ridges, they have cut patterns, grooves, into the idler soft face, this might keep the idlers from “floating vertically” when moving with the motor shaft? I’d use some 2000 grit on a small flat piece of steel (hard flat surface) followed by 3000 & 5000 or higher. Using caution as Bill states, not to remove too much material, but I’d want those ridges smoothed out, but hey, that’s meYikes! My spindles, are they supposed to look like this, for traction? Or do these need a little light cleaning with a scotch brite pad or chemical cleaning?
Andy
Wow! My feeble experiments with turntable power supply have been related to shielding, voltage reduction and such, don’t have things that “clean up” sine waves or stabilize output….And I just remembered, I am going to locate my AC power supplies today which I bought years ago and have never used but I can't imagine a better use for them than to drive a turntable motor. They are commercial rack mount AC amplifiers, 45Hz-4KHz, 0-135VAC, 500-1500W out., .001% frequency stability. They are a bit big and clunky but I have a 7' equipment rack in my living room which will hold one nicely. I will post some better pics later, these are from the day they arrived here from California.
More later...
View attachment 2832656 View attachment 2832657 View attachment 2832658
I now realize my brain thinks I am 25, my body thinks it's 85, somewhere in between is reality. I spent 3 hours on the weekend trudging thru snow up to my knees to get the variable AC supplies out, I forgot they weighed 80-100lbs each, monsters, thankfully they slid well on the snow and I got them to the shop to warm up. I now am thinking I am nuts to use these as they are WAY overkill for a 5W TT motor, all three are good for 1500W out. I am going to investigate Nigel's offering and maybe come up with something similar on my own. I haven't read the thread, I just glanced at the schematics but I didn't see a power stage, only low level stuff, I need to read the whole thread to grasp his concept.
And now I am back to work full time so hobby time is relegated to evenings and weekends only and about all I could muster today is to clean the spindles. Here are the after pictures. I used a lathe tool steel blank as backing for 400 W&D paper (used wet) then 800 W&D then a buff with scotch brite. I didn't see a need to go to 3000 grit and then polish it, if I am wrong please correct me and I will continue with the finer paper. I thought the spindle would need a little bit of traction, and even 800 is pretty damn smooth.
Cheers
