Thanks Andy, I ended up using ISO 46 hydraulic oil, heated it on the wood stove then let it cool in the can of oil overnight, it should be good now. When the table is going back together I will fill the well with the same oil.
Today I stripped one of the tables….cleaned it all and it's ready to go in for powder coating, bright red, should look good with black or chrome tonearm. It's a shame as the finish is darn near perfect but I just don't like baby blue, I'll probably keep the other one original.
I'm just going to coat the top surface, and only what's visible, keeping the underside and under the platter area clean so I can put damping pads on….Still stewing on the whole look but I have time.
More later.
Cheers
Thanks Andy, agreed, would be good to hear from Bill.
Heeellllooooo @BillWojo can you hear me now?
I was rereading @MisterDK thread and he made a wood idler arm, I would like to know Duane, how that sounded and how it worked. I think wood would be better than my idea of Delrin. I have a nice chunk of maple which I could mill into the proper shape. Duane, how did you get the shafts out of the original idler arm?
I may be chasing a non audible problem at this point, but it is fun to experiment.
I'm listening for input.
cheers
@ve7kilohertz , do you have access to a dial indicator⁹ setup?
Aside from that I just took the motors apart and cleaned/ lubed the bearings. Also check them for play, should be very little. BillWojo
Got the dial indicators from the shop and set it up on the spindle, only a needles width of wobble, see attached link to a video I recorded, gauge markers are .001".
Going to redo my spindle bearing today using the newly arrived Delrin rods. Mmmm, actually, I don't think I will, forgot, I need to find a collet setup for my lathe, I have the collets but no way to use them (that I know of).
Here is my measuring setup and video link.
Cheers
https://drive.google.com/file/d/1DVLoVSo8J4dIU4ne7BvG0wTdf_kLdkZR/view?usp=sharing
To be a bit nitpicking, my approach to this test is with the motor powered up….
so maybe it’s just me
