Awesomeaudio
deleted
Coming up...
deleted
that pic only shows one cap ..
next time if you take your own pic before working on stuff you will have a good reference .
yes it cant work properly like that ..you are lucky they didn't explode ....kaboom ..
looks wired wrong to me ..
you tied negatives together
you need to replace both of them now
you should have ground to plus on one cap then to minus on the the other one .
then plus wires to the cap with plus terminal and negatives to other cap .
here is a simple diagram .....
hope you put them in and are good to go, I will see if I have a pic showing both.
I usually draw a detailed diagram, I will also see if I have that.
ok just looked at your pics now, the cap you copied off mine is correct (red/white/black) the ones on the other cap are backwards.![]()
Good Luck!
