ok center trimmers should be the 4.7K and are the mid-point potential adjustment using pins 2 and 17. I never use multiturns.
outside trimmers are idle current, (100) and are adjusted at points 1 and 3 on one side and 16 and 18 on the other.
If you are trying to rotate a trimmer in circuit you very well may not be able to get a measurement. If you go across both outer legs it will tell you if it is the 100 or 4.7K. (In circuit) You would have to pull if you wanted to rotate and set at a cetain setting like the old trimmers. I think Mark wants to make sure you have the 4.7K trimmers on the inside and the 100 on the outside.
