Awesomeaudio
For the trimmers I always go by the 3386 data sheet, and choose the proper value, then match the pin out orientation of the originals, and then location of adjustment screw.
*******If you have the opposite pin out the leads on the trimmers are to short to bend the other way.
I like these also:
Have used them on many Advent 300's.
http://www.digikey.com/product-detail/en/3329S-1-202LF/3329S-202LF-ND/1060399
Check the above data sheet for part number for pin outs and style
If you need help picking out let me know if facing the heatsink are there 2 pins up front and one center rear, or a single pin up front with 2 in the back?
You are probably going to need top adjusters for the 2 center ones, or if you need the ones you have in the pic, see if you can angle them to the outside so you can adjust them, that is if the pin out are correct.
The trimmers I already have, These were on the list Mark put together for me. I purchased them as directed so I assume they are the right ones, ie, value etc.
I just wasn't sure on the orientation.. pin out.
