Alright I will make one last post for a while and then I am just going to deal with it as is for a bit. It's quite possible that when the weather turns colder it may work fine until Spring rolls around...
As far as the bulb goes... I don't see how that can be an issue. From what I understand the only symptoms you would get, if there were interference between the bulb and the remote sensor, is that the remote would just not work sometimes. And that is not a symptom that I am having at all. Not to mention that I am using a bulb that is specifically designed for garage door opener use, so it should not produce any interference at all. The symptoms that I get sometimes are while using the wall switch as well. And the symptom is a total loss of power to the unit. Sometimes it comes back on, sometimes it doesn't and sometimes it comes back on after I give it a good whack... Also I can almost predict when the thing is going to fault because the bulb starts to flicker just a bit. Once again all these symptoms would point to a loss of power somewhere in the chain. I don't know if a motor being on its way out would give these symptoms either, but if that were the case why would the bulb flicker like that?
The sensors are clean and aligned properly. Both lights (sending and receiving) are green and when you step into the beam the receiving sensor goes red and you can hear a small click in the unit itself. So no issue there.
I put the door up this morning and left it that way. No reason to tempt fate as I go to work in an hour or so. I will run it down at that time. Sometimes if it doesn't go down by itself I will hold the wall button down and that usually works, but not always...
Also it was over 80 degrees here today and that generally means that it is going to mess up. It messed up during the day yesterday but then worked fine later in the evening when the temperature cooled down. The guy at the dealer even told me about a woman would had the exact same symptoms. It wouldn't work properly on hot days.
All signs point to it needing to be replaced. Because even if I do get it going how long is it going to last when it is already over 30 years old?
And by the way, it is a chain drive and not a screw drive. A Raynor R170 unit manufactured in 1995... The Raynor units are quite good and well respected but I doubt they were designed to last more than 30 years.
