VinylAddict8
Thanks mbz, I've read your contributions in a few places on the 1000ii, appreciate you responding!My opinion... fusibles resistors must be checked, if they are still within spec then ok to leave them in...
The CA-1000ii is slightly better than the CA-1000, this pair has a different sound campared to the 1000iii/1010 and the 2000/2010.
These are all great integrateds, the end choice will come down to what sound you like and speaker matching, my pick is the
1000ii...maybe, the 1010 is a beast and the 2010 is refinement, again all opinion...
I'm thinking of just getting it, checking (maybe with help from the knowledgeable folks here) --- and if it needs to be replaced maybe its something I'll tackle. I know my way around a soldering iron, electronics --- but have never undertaken anything like a complete overhaul of an integrated or anything that scale.
If they did need to be replaced, how much disassembly is required in the case of the 1000ii? Is it a simple change, or does it require tearing the whole thing down?
