My Yamaha CA-1000 Restoration / Modifications Thread
Thank you All for your input. I was able to adjust the TP3-4 for Normal Class AB 47mV and Class A 94mV for both ch. Tested the amp works fine BUT still one problem is the L ch (which was R ch before amp board swapping) gets hot even in Class AB whereas the other Ch (currently R) not hot just tiny warm.
In the currently L ch the Tr 609 (2SC680) gets very hot.
  • Like
Reactions: mbz
Set operations to Normal. Measure voltage at left power amp wires A,B,C,S +/-50, +/-B, D607 anode
L ChR Ch
A-0.65-0.36
B2.171.86
C2.171.86
S4.444.43
-50-50.50-50.56
5050.2350.46
-B-49.01-49.26
+B48.9949.21
D607 anode1.501.18
D607 cathode0.830.52
D605 anode0.1920.000
D605 cathode-0.013-0.013
  • Like
Reactions: mbz
L ChR Ch
A-0.65 -0.36
B2.17 1.86
C2.17 1.86
S4.44 4.43
-50-50.50 -50.56
5050.23 50.46
-B-49.01 -49.26
+B48.99 49.21
D607 anode0.192 0.000
D607 cathode-0.013 -0.013
Voltages don't look too bad, certainly wire C is a little high.
Did you change TR606(2SC458LG) mounted on the heatsink. Most use KSC1815 as a replacement, round face to heatsink, will study voltages.
edit odd that the S point voltages are the same, but then B,C are significantly different.
Inspect R615(470) try measuring in circuit.
With the amp powered off/unplugged measure the resistance between the C & S wires on the faulty left channel, operations switch set to normal, expect open/OL
Thanks lot mbz.
R613/614/615/616 are the very much same for both ch. in circuit R615 467 for L and 478 for R
resistance between the C & S wires 467 for L and 469 for R ch
thanks
Apologies, I had a "blonde moment"
Can't see the forest for the trees...
Was it replaced? Need round face to heat sink
Can you post a hi-res pix of faulty left channel board both component side and solder side
D605 cathode should be connected to GND, looks like you have a minor GND problem, not the cause of this problem. With amp powered off connect black MM probe to black/GND wires/pins on the electrolytic board then with red probe measure the resistance at,
- any black speaker post
- phono chassis GND lug
- at each black GND wire ("e" and "E") on the power amp board
- AUX RCA outer/GND
- black GND wire in yellow wrap on volume board
All should be less than 1ohm (abouts)
Back to the problem...
TR606 Vce is about 2.17(C wire) - -0.65(A-wire) + (0.65) TR606Vbe = 3.47V
for the working side
TR606 Vce is about 1.86(C wire) - -0.36(A-wire) + (0.65) TR606Vbe = 2.87V
TR606 is working a little harder but significant???
Still puzzled by Same wire S voltages but difference at wire C
Anyone with ideas???
Thanks mbz again. Really appreciate.
I have measured all the res between all these you mentioned above. I put MM black in a black wire pin on the elec cap board then measured all the res. They are all pretty much 1.2-1.6 ohm. Aux1/2 is 1.6 ohm all other about 1.2 ohm.
