I just got an NAD 1020 off the bay with all original purple caps. Everything is in really good shape, but the preamp sounds very plain right now, nothing special. I am hoping to help it out with a recap.
I have gone over the thousands of posts on recapping NAD 3020/1020s here, but I still have a few questions before ordering caps. I really hope these questions don't sound too dumb.
1. In the NAD 1020 Service pdf, it shows C519/520 as 100uF 10v. The 1020 that I have has original 47uF 10v caps. So, should I get the 100uF or 47uF?
2. I have read when using Nichicon KL in the signal path, a small bypass film cap can be used to smooth higher frequencies. How do you install a bypass cap? And do you install them on each one of the Nichicon KLs?
3. And which caps are in the signal path? I figure the C9xx caps are the power supply caps. Are all of the C4xx and C5xx caps in the signal path?
Thanks
Thanks
