Signal path caps are shown here in green. Sure, it's for a 3020 amp not a 1020 preamp, but the circuitry is the same :
https://audiokarma.org/forums/index.php?threads/nad-3020-rebuild-and-upgrade.460678/
Signal path caps should be Nichicon KL or WIMA MKS2 film, depending on what will fit (or what you are willing to spend). C401 and C417 I would definitely use WIMA films if you plan on listening to vinyl a lot. Later amps and preamps use a 10uF for the cap in the phono stage output, you can JUST squeeze a 10uF film in there.
Elsewhere, use Nichicon KW or PW. For the final output caps, you could try an ES instead of KLs, these are the four caps behind the volume control.
Power supply caps should be PW, you can up the main ones from 330 or 470uF to 680uF.
Carry on.
Carry on.
