There are several upgrades you can make to bring the amp up to spec. Tried to upload as a file but didn't work so here they are in full:
Left,Right Channel
C101,102 0.82uF polycarbonate
C103,104 0.82uF polycarbonate
C105,106 2.2nF polystyrene
C107,108 1nF polystyrene
C109,110 replace with short if servo, else shunt with 2uF polypropylene
C111,112 10uF tantalum
C113,114 10uF tantalum
C115,116 replace with short if fitted
C201,202 180pF polystyrene
C203,204 replace with short if servo, else shunt with 2uF polypropylene
C205,206 470pF polystyrene
C207,208 replace with short if servo, else shunt with 2uF polypropylene
C209,210 0.1uF polypropylene
C211,212 390pF polystyrene
C213,214 100uF tantalum
C213a,214a 2uF polypropylene
C215,216 1000uF electrolytic
C215a,216a 2uF polypropylene
C217,218 1000uF electrolytic
C217a,218a 2uF polypropylene
C219,220 47uF tantalum
C221,222 47uF tantalum
C223,224 1uF stacked mylar
C301,302 4.7uF polycarbonate
C303,304 4.7uF polycarbonate
C305,306 22pF HV polystyrene
C307,308 1nF polystyrene
C309,310 1nF polystyrene
C311,312 47uF tantalum
C311a,312a 0.1uF polypropylene
C313,314 0.1uF stacked mylar
C315,316 330pF polystyrene
C317,318 330pF polystyrene
C319,320 150pF polystyrene
C321,322 150pF polystyrene
C323,324 47nF polypropylene
C325,326 6.8nF polypropylene
C327,328 6.8nF polypropylene
C329,330 0.1uF polypropylene
Power Supply etc
C401,402 47uF tantalum
C403 22uF tantalum
C404 0.47uF stacked mylar
C405 no change
C406,407 1uF stacked mylar
C408,409 no change
C410 0.47uF polycarbonate
C411a,412a 6.8uF mylar
C413a,414a 6.8uF mylar
C415,416 6.8nF polypropylene (value changed in NAD2200A)
C417 not required - remove if fitted
Distortion at 80W 2kHz measured at 0.003%. Couldn't measure it at 1W as my distortion meter doesn't go below 0.001%.
