Since I rebuilt this, I've listened to it with lots of different pairs of speakers, including some that aren't that efficient. It has never failed to amaze me with the sound quality. As I said it previous posting, I find myself looking around at the speakers thinking "I've never heard that before".
I reckon it must be about $60-70 all in for parts. If you can hold tight, I am making up a spreadsheet with all the parts used, including Mouser part numbers... because I'm going to build another one...
Upgrading to what? If you mean the outputs, they are already massively over specified for an amp this small. I've seen the 3055/2955 combo used on amps rated at 150w. Somewhere else I heard them mentioned as being "slow". Well, we're only amplifying audio signals here, do we really need 200mhz outputs?
As for just being sold, yeah, I sold it. But only because I have another 3020 that was a parts unit that I plan to bring back to life. This time, all the transistors will be replaced as well, most of them are missing anyhow. I also have a 1020 pre-amp that uses the same circuit board, they just didn't fully populate it. I might turn this into a 3020 turbo, with an uprated power supply for the power amp stage, using a compact toroidal transformer. It might even get four outputs per channel, who knows? The only limitation is the small case these things came in.
Lee.
