Another happy NAD owner though!
The feedback they left simply said "sounds awesome!". The feedback another buyer said about the 1020B preamp I recapped said "sweet sounding preamp".
Lee.
I have two projects saved with Mouser. One is pretty much all the caps and resistors, the other is all the small signal transistors, diodes, power switch, TO3 mounting kit etc. If anyone would like me to share these projects to make it easier for them to order, please PM me your e-mail address. Once again, these are just as a starting point, you might need/want to amend what's on there. But I did just order these myself to start rebuilding an early 3020 I have, so they aren't all bad.
jheu02 said:I'll typically replace the really low value electrolytics (<= 1uF) with a film cap if it will fit. UKLs for the low leakage ones (typically orange sleeved Elnas in '70s gear) and will also use them if when I replace the tantalum caps as they were also known for low leakage properties. Power supplies will. Usually get Nichicon PW, PM series or Panasonic FC, FM, FR. Bipolar caps will usually get the Nichicon UES series, though I have used Panasonic SU series and prefer film if I can get them to fit.
Earcraft said:Leesonic> This may be a silly question, but what is the brown thermal paste you are using under the new transistors on your latest build? I was planing to replace the paste under my original transtors when I recap mine... just curious what you did because it looks so clean.
Binkman said:Q: Why install those 'risers' for the resistors? Are they ceramic?
Binkman said:Your pics reflect you craftsmanship. Reminds me of those immaculate older Onkyo tube amp boards they used to make in Japan where they post them on their now defunct website.
Hi Lee
Very pretty Job.
I have a 3020i on a shelve and you give me the desire to renew it. But I have a question: how did you clean the pcb? It looks like if it's just get out of the factory!?
And thank's a lot. It is very kind of you for sharing your experiences...
G.
Light blue Sanyo electrolytics are considered by some to be evil incarnate, they are known to fail in Pioneer equipment, and there are two 0.68uF right by the bass control on the 3020. These can be replaced with film.
Lee.
I'm getting ready to press "GO" on my Mouser order so I reviewed the thread again (commitment issues). You state to use Film Caps to replace the Sanyo Devils. Would there be any benefit or dis-advantage using Solid Polymer Tantalum caps?
Thank's a lot Lee.
Simple and efficient...
I always had dirty white things after cleaning solder flux and I asked once to a professional who told me it's necessary to blow solvent with compressed air to avoid any tracks.
I finally finished the re-cap of my 3020A. It's pretty and clean and broken![]()
After firing it up and adjusting bias and DC offset, I did a listening test. The audio is was completely distorted at low level and consistent across both channels. That's when I checked the fuses to find both 4A (F3,F4) blown. After checking cap polarity and a good inspection of the traces looking for shorts, I tried another pair and they went pop the way only slow-blows can.
I guess I'm looking for some advice on where to start looking. I can say that one of the 4A fuses was blown when I started the dis-assembly so there is hope this is not the result of my handwork... but it probably is...
I know AK'rs love pictures so here are a couple.
