HIFIuk
Hi I'm new here so thanks for accepting me.
I'm in the process of recreating my old 1980s system. I have my 2 Roger's LS7 speakers that seem to be ok. The amp isn't well unfortunately. One channel is distorted (only at.low volume as far as I can tell).
Same distortion via the headphones too if that makes a difference...
I have switched over the pre out / main in connections and the issue remains on the same channel. Google suggests that if this is the case it's the power amp, driver, or bias/DC offset circuit. I've yet to clean all the pots with switch cleaner so it may just be this but I suspect something has failed. I don't have a scope. Any suggestions or anyone else had a similar issue?
Thanks in advance!
Thanks in advance!
