Samuel STEIN
Member
I'm not getting a loss over R505 or R506. Looking into this.
Collectors of Q501 should be about +35 vdcBefore we go there, I'm getting +/- 35V around of readings in the collectors of Q501 and Q502, and ground from the emitter and bases.
What do you mean by "good at 6.5V". If you are checking between each pair of leads (total of 6 measurements) using the diode mode of you DMM, then you should expect so see .40 to .70 for a forward biased junction and OL or other open indication for a reverse biased junction. Do need to check these out of the circuit.Q501,502,505,506 are good at 6.5 V, but painful to get out. Checking the easier ones now
Don't understand what you are doing. "3/4 were .7V" 3/4 of what? "One of the legs of Q504 was grounded" Grounded to what? you need these out of circuit to test them.3/4 were .7V... BUT one of the legs of Q504 was grounded, so part 1 to replace!
