Samuel STEIN
Member
The 18V (P525,P524) are coming up at -27 and 22 though.
If I understand correctly, when you measure the resistance from the collector or base of Q502, your ohmmeter shows a low resistance at first, then creeps up. That would be normal as the ohmmeter would have to charge some pretty large capacitors. Now getting a shock off of Q502.... 35 volts is getting up there a bit. It's still considered "Low Voltage" until it reaches 50 volts. I can't feel 35 volts on dry skin, but some can.Also, on Q502 (because I was shocked on it's heat sink), I am measuring between the collector and sometimes the base legs and ground,I get a beep on my resistance-ground mode, but the resistance then climbs. Is it because I am playing around with a receiver thats off where everything is grounded, or because it is grounded? (I visually inspected and saw no obvious ground.)
Did they show a large leakage or did you do an ohmmeter check on them?I took out the two capacitors C513, 514 and they're reading 1.2nF which is less than the 10K uF they should be, but I assumed it would be the opposite fail (as in it would make the voltage zero, not higher).
Ceramics rarely fail.The ceramic capacitor was reading 22nF, which seams right
If you are replacing the bridge, the W02G would be the appropriate choice.The diode is also good if it's the same as https://www.mouser.com/datasheet/2/427/woo5g-280147.pdf
If C513 and C514 are measuring only 1200 uF, then i would suggest you replace those too.Ordering the transistor and these two diodes. I feel like i should probably spot check some more capacitors or buy one of those emf testers.
Without Q505 and Q506, the receiver doesn't click, and P522=-37, P521=36.7, P525=.72, P524=2.78, P902=12.2, P901=5.78, I am going to follow P525 to see where those 2-3/4V are coming from.
