meako
Preamp section seems to working. All connections and pots cleaned with contact cleaner. Power section seems to be the problem. I used a NAD 7150 preamp section to test. Right now the right channel sounds clear with no distortion. Left channel is just completely silent, even on headphones. I hear the relay click quickly when I turn on the amp. Visual inspection of fuses, all four seems to be intact. After moving the tuner board to expose the power amp board, I don't see any burnt or leaking parts. It actually looks very clean. From the Main IN to power amp to just before the speaker relay, all wires seems intact. My gut points me to the speaker relay as the culprit. Visually, I see the audio signal passes through it (duh?) before going to the headphone out and speakers out. Now how do I check if the relay is faulty? Also Can I check if there is a L channel signal before the relay? Thank you very much for any ideas.
