Q42/2sa1220 tested good…q44 tested good too
The -26V rail is set by Q42base
If Q44 is off then there will be no/very little current flow in the loop R42, R44, R48 so Q42b will still be about -50Vdc.
Also, that -26V rail tracks the +26V rail via R414, R412, R410, if any have failed then Q44 will be off.
Suggest the following dc voltage measurements, DBT not connected
- one side of R414 (+26Vdc?)
- other side of R414 (-1Vdc?)
- one side of R48 (-53Vdc faulty)
- other side of R48(-53Vdc, faulty)
- resistance check mentioned resistors, in circuit is fine, need to confirm none are open
Regarding the
+26V rail
Voltage is set by Q41base so if Q43 is off then the +26V rail will be abnormally high.
Look at faulty Q43 or failed zener IC301 or failed resistor R49, R411, R497, R496
