I appreciate the input guys!
I can easily fashion an aluminum plate to affix the arm mount to the t-bar. But with the arm pivot offset to one side of the t-bar the only way I can think of to compensate for the torsion would be to make a 'T' shape plate with a mass opposite the arm on the other side of the t-bar. The problem with that approach is the limitations of the burl shape and the limitation of my brain to determine where to locate the balancing mass and how much mass is needed? Then the arm and the balancing mass is going to play havoc with the spring rate as I imagine it might triple the original arm mass load on the t-bar?
This is fun stuff!
This is fun stuff!
