Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Need more photos of the driver itself. The horn is the 811 used in a plethora of applications and with numerous drivers. Plus it appears to be a couple different ones.
They look like an 806a or something in that size. I believe the 802 variants are larger, but it’s hard to tell. Can you measure the size of the drivers?
Also, if you remove the back cover carefully (don’t dent the diaphragm), you can tell more about which model it is based on the type of diaphragm. It will have either the aluminum or the symbiotic which has the phenolic ring. This will also help narrows down which model you have.
The driver is 4 1/2 inches wide, by roughly 3 1/2 inches deep. Anyone know why there isn't the word Lansing in the box under Altec? I've looked at probably 50 drivers on ebay and Google images, all of them say Lansing in the box.
I wouldn’t worry about the lack of the word Lansing. They changed the cover a bunch over the many years that these were in production. You should be measuring just the magnet, not the covers too. 806 have a magnet depth of 3 1/4” while the 802 has a depth of 3 11/16” according to what I saw online
The driver is a 23746, it is unique to only one speaker system that Altec made, was used with a 1500hz XO, and it is a delicate driver in original stock form and should not be used down as low as 800hz without judicious care if the original diaphragm is intact.
It's an early one with the old style rear cover, and the 50th week of 1974 date code verifies this.
If the original 23744 "light" diaphragm is still in it and working, you got a bonus.
