tusntuk2
Need help replacing KR-5600 bridge rectifier S5VB20. I used dlucy's suggestion of a 400v/35a bridge on a previous KA-3500 restore, but I found it larger than the original. Space is tighter in the 5600. Could I use something like a KBPC804PBF? It's 400v/8a (Vishay). I plan to use 10,000uf caps to replace the 7,500uf originals. I'm not sure what is most important here - heat? - initial surge? - physical layout? You guys are the best! Thanks.
