Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I thought it was fairly common knowledge that CJ preamps invert phase. This is the first time I've heard of it making an easily audible difference.
It's relatively easy to hear the difference between correct and inverted phase with some instruments. Brass is a prime example. Because brass instruments produce an extremely asymmetrical waveform they are a prime example.
Generally, any amplifier that has one or an uneven number of stages will invert absolute polarity. Each stage inverts polarity.
For the curious check out The Wood Effect by Clark Johnsen.
The old Audio Annual Equipment Directory had a specs column that indicated if a piece of gear inverted absolute phase.
Newer B&W speakers have an octave to octave and 1/2 wide peak centered around 10 KHZ which make the sound seem very shrill to me. But I bet speaker room placement and your seating position need to be modified.
