Russellc
Addicted Member
I just had to do it. Gary's mono pair is different from my F5 in 3 ways:
- Panasonic filter caps instead of Cornell Dubilier
- HEXFRED rectifiers instead of standard Vishay rectifiers
- Toshibia outputs instead of Fairchild.
Speaker cables are from Blue Jeans, MAC Sound Pipes for interconnects. Source is a 160gb ipod full of lossless goodies.
I can't think that splitting into two chassis makes a lot of difference, perhaps some on real dynamic tracks with lots of stereo separation where bass slam on one channel robs from the other in a shared/common power supply. But I don't think that I'm listening at a level that would affect that.
I have been listening to Miles Davis' "Right Off" from A Tribute to Jack Johnson because I'm pretty familiar with it.
First up was my amp. Upstairs I feed it with a passive pre and use RayW built Indignias. Right now I have my Yamaha C-2x and Cornwalls going.
I like the sound of Cornwalls with the F5, certainly has a better low end than the Indignias. The immediacy and intimacy of the F5 is still there. However there are a couple of moments where Miles' horn in the right channel is a tad harsh. Not bad, but in this case noticeable and a bit surprising because I hadn't heard that in the Indignias.
Moving the speaker cables from my F5 to Gary's was a snap. Gary did you know that your binding posts have a locking feature? You have to unscrew them before inserting banana plugs.
Right away the difference in amps is apparent. The low end is just a tad more taught, the overall impression is that things are a bit more pure. A more "natural sound", to coin a phrase.
The bass line at about 13:55 of Right Now has an attack to it, the following organ notes and guitar "wah wah" jumps out at me. The crescendo organ section sounds pretty cool - has kind of a brash brittleness that jumps out and grabs me in a good way. The trumpet comes in and there is none of the harshness that I heard with my F5.
I have the HEXFREDs, I'd better find another set of Toshibas pretty quick.
Are you sourcing the Toshibas from the guy on DIY? I'd like to aquire some,
also did you alter any component values from standard due to the Toshibas?
Thanks in advance,
russellc
