Scott Muni
Well-Known Member
I grabbed a AU222 from that auction site. It's in pristine condition, just some dust inside and all original. Cleaned the dust and squirted the pots with cleaner only. Fired up on a 40 watt dim bulb and no shorts. Plugged a 1k signal in, and left channel had no signal output with loud hiss when headphones connected.
Traced signal with scope and it disappeared at the base of TR8. Checked voltage at base, and was near 10.0. Collector voltage was 9.0 and emitter higher than schematic. I then checked esr on caps and were surprising low. Resisters near tr8 all checked good in circuit. I decided tr8 (2sc871) was shorted, so popped it out.
Checked on pocket tester it showed good, and HFE was 260, a little low. Also checked with dvom and that showed good. I took my best guess and tossed in ksc1845f, and it's up and playing. Voltages are close to schematic.
My question is, the transistor is NG, so how does it test ok? I'm guessing a analog ohm meter might show it shorted.
This little amp sure does lay it on thick and sweet!
