I finished this one over the past few months. Got it to play without noise by replacing all small signal transistors. It sounded ok but tired.
I planned on working in steps to hear the changes. First thing was to replace the power supply rectifiers with soft recovery ones. To my surprise this alone made an audible change for the better.
Next was the power supply caps. I used nichicon FW series, as the data sheet claims ok for audio power supply. The values were increased, the main cap originally was 1500uf and is now 6800uF, it has a ripple current rating of 3a at 120hZ. The tone board decoupling were doubled in value over the original. Output trans emitter resistors were replaced with 1% non inductive type. Played for a few weeks, but not much change in sound.
I then did the Baxandall mod as per leestereo advice. I noticed an immediate change in the high frequencies, they were distorted and shrill. I then added a .33uF polypropylene cap across the bases of TR805/807 and TR806/808. Mounted these on the trace side. This helped and brought the high freq sound back to normal. This changed the sound alot, it's bright and the bass has more punch.
I saved the output caps for last. The stock values of 1000uf were increased to 6800uf. Leestereo did this on the au555a, and it helps with the low frequency. Nichicon LKS were used here, and this made a noticeable change in bass response.
The phono eq was recapped, but no mods done here.
All switches were disassembled and cleaned, the pots were cleaned with contact cleaner and a dab of F5.
Been playing for a week now, and this little amp simply rocks! The sound is very similar to my rebuilt au555a, the bass seems to have a bit more punch, and it's a tad brighter. Overall it's amazing! Perfect example of less is more.
Special thanks to
@Leestereo , for the baxandall advice!
View attachment 2811467 View attachment 2811469
