New class A is a dynamic/sliding bias system that is supposed to reduce crossover distortion, resulting in the benefits of true class A, without its drawbacks (heat and inefficiency)
The Technics gear with "New Class A" (or "Class H+" in their later series in the 90s and early 2000s) that I'm familiar with may have had
relatively less heat generation, but they still ran hot as hell compared to their competitors' A/B amps. :yes: (btw I'm a fan of Technics gear in general so am not complaining about it).
This is based not on internet heresay but actual experience, while selling Technics receivers in the mid 90s and owning one of their receivers bought new for nine years now, an SA-DA8.
Even while idling with the volume turned all the way down or no signal being sent from a source component, the metal in/around the cooling vents on top of the receiver can become so hot that most people can only keep their hand there for a couple seconds at the most.
* What's weird is that their internal cooling fan, if equipped, only turns on when the volume reaches a certain level, usually around 10:00 on the dial (if using a mechanical/potentiometer-based knob - my SA-DA8 does, the last one for Technics AFAIK), which with my Boston CR9s is already loud enough to easily prevent a normal conversation.
Btw I never worried about the Technics new class A heat issue because car audio gear can last years and years, and look at the conditions
they operate in. And related to that: Technics engineers must have done their Q.C. homework because Technics was our most reliable receiver brand, despite their heat-generating ability.
Lastly, I found this thread last month and bookmarked it:
"New Class A, Super-A, Non-Switching : need a revival ?"
* some customers would change their mind about buying a Technics receiver for that one reason. Fun factoid: my SA-DA8 can literally help heat my 11ft x 14ft mancave, enough that in the summer sometimes I have to open the door; Me? I think the hot-as-hell amp feature gives Technics receivers "personality", weird but true.
