Please help me understand?
Back in the old days class B and class AB amps
What is your distinction between Class AB and Class B?
had crossover distortion changing from the positive to the negative and back. , where Class A amps didn't. Todays and designs to come along in the 70's that one issue was pretty well controlled.
If the problem of crossover distortion has been solved for the past 40 years, then what is the advantage to class A?
Class A amps can drive very low impedances if they have a strong power supply enough devices and adequate cooling. It was an important issue when paneled speakers impedances could down close to one ohm, which really compromise other classes of amps.
But power supply, output devices, and cooling are important for all the other amp classes, and given enough the other classes can drive low impedances as well. With the dissipation requirements and low efficiency of class A amps, their performance is even more dependent on these things than other classes of amps. All else equal, most of the time a class A amp is running on a smaller safety margin.
The issues with Crown was keeping them cool and making sure the wall receptacle had more that 15 amps and didn't sag below 120 VAC.
A sufficiently low impedance line supply and adequate cooling are necessary for *any* amp to make its rated power, how were these unique to Crown?
Class D amps have really improved over the years, but as far trying to compete with other classes of amps for low distortion, signal to noise and other parameters they are still 10 to 15 years behind the best Class A and B and AB amps.
How have class A/B/AB designs advanced significantly in the past 10-15 years?
Speaker impedance isn't constant so if your speakers dip below their rating significantly, better class A designs do provide up to 100 % more power than they are rated when necessary.
Sounds like those class A designs are simply underrated? Which is odd, because a class A design is usually a struggle to survive idling without catching fire.
Where lesser well amps designed amps with inferior cooling, heat sinking and current protection will fail miserably. So in that case a Class A Amp can put out more current and there fore more power where other classes might fail.
That doesn't make much sense. An amp design just needs whatever heatsink, cooling, and protection is necessary. Class A amps inherently require relatively more heatsink and cooling, because they are dissipating maximum heat when idling. A class AB, G/H, or D amp will be dissipating very little at that point. A class A amp will run at maximum efficiency when it's driven into hard clipping to the point of making square waves- but that's true of the other classes as well.
Doesn't mean they will. Nothing is written in stone.
But yet you say:
Today amps will tell you what they can handle, if not look else where.
So if a class A amp can put out twice its rated power, one should look elsewhere?
