No.I am wondering is a 100 watt class A amp more powerful then a 100 watt class AB amp!
A watt is a watt.
They think it sounds better. Does it? We can't answer that for you.So why would someone purchase a class A amp that weighs a ton and probably has fans in it also in efficient as suppose to an amp with half the weight, half the cost and more efficient to power a speaker?
Because they can.So why would someone purchase a class A amp that weighs a ton and probably has fans in it also in efficient as suppose to an amp with half the weight, half the cost and more efficient to power a speaker?
The one with the highest resale value.which one would you choose?
Haha. I should have knownThe one with the highest resale value.![]()
That answer I was looking for. The quality of the signal might be better to some listeners even though they are getting the same power.So is a Class AB amp. Or a Class D amp.
The power going to a particular pair of speakers at a particular volume is the same regardless of class.
The efficiency (sensitivity) of a speaker is irrespective of the power source.
Class A amps provide higher linearity and less crossover distortion. It is hard to know if you can hear the difference between and A and AB amp, since when comparing one to the other, since there are other variables which can also play a role in the sound of one amp vs another. That said, there are certainly users who feel strongly that Class A amps sound better than Class AB amps, all other things be equal.
For them, the expense and heat are worth it.
So, while the quality of the signal may be better from one amp vs another, the power going to the speakers is the same regardless of amp (assuming no clipping).
