bill114
You don't want to block the sides-only the front-to prevent cancelation.
Leave the sides open.
I think I posted a picture that had the front and the sides blocked off-and after listening realized my mistake-I should have corrected the picture.
My first system (2nd still under refrub) has the AMT3's up against a banister on a slpit level-which really seems to work well.
Addressing the bass issue again-I think if you stick with the stock woofers-the amp becomes more important. Part of it could be Alnico discharge-but the woofers aren't as efficient as the AMT, and possibly transition driver. A fact with other woofer tweeter combo's as well.
The H/K amps I have seems to have enough drive in the low end to make up for this.
I experimented with a few other amps, and non seemed to work as well-despite having high power.
The Acurus A250 was probably the worst of the bunch-not a good match with the AMT3's-thin bass, brittle highs. I didn't however try it with the matching Acurus preamp.
I would love to try them with a Citation I or V amp/preamp combo, as they never seemed like a 'slow' tube amp when I listened to them, and have great bass response-especially the V.
The main reason-in a nutshell I went back to the stock woofers-was because I found myself listening to the speakers instead of the music-like I was when I got my first pair of AMT3's-and I missed that.
I like the speakers disappearing and just have fun with the music.
I also ran into this when demoing cd players recently, and settled on one that played music and didn't draw attention to one specific thing.
Again a issue of taste.
So you're saying only block the areas beside the Heil to prevent any sound from coming from behind but leave the side openings open?
I do like the big heil Tweet's though.
