Hi all,
New forum user and new owner to the Yamaha GT-2000 TT.
I'm having some issues getting this TT to sound right. The main issue that I have is that with ZERO anti-skate added (it also didn't come with anti-skate weight, does anyone know this weight?), the tonearm flies off the outer edge of the record. I've already took apart the bearing pivots and cleaned and greased them with a light duty grease. Would anyone have any recommendations on how to resolve this?
Current condition of fault:
ZERO anti-skate weight with the tonearm floated (balanced with no tracking force added) and moved to the towards the spindle, the tonearm moves back to the outer edge of the lp.
Original Yamaha GT-2000 headshell installed with a Mofi StudioTracker cart. Recommend tracking force 2.0g and maxed out on the tonearm for 2.2g. With ZERO anti-skate, the tonearm still flies off the outer edge of the record.
I hear a lot of distortion in the upper treble coming from the right channel when playing the inner most track and outer most track. In the middle, the distortion is ok, but still present.
Does anyone have an exploded diagram of the inner workings of the center pivot? I don't want to take this apart.....yet. Do I need to use the rubber pad on the lifter to dampen this movement? What am I doing wrong?
Thanks for your advise and help. I've been lost in information overload these two days. I'm seriously considering moving back to my Rega P6 if I can't figure this out. Ugh.
