at least I'm not alone with that weird issue...
This seems to have been the solution to the issue?
So I had to rebuild the tonearm. I tore apart the tonearm and found the source of the torque that was acting on the wand when it was centered over the spindle. There's a manufacturing defect in the C cup that cradles the wand and wand holder for the horizontal axis movement. The top and bottom of the needle bearing screws are in bore axis centered to each other. As a result, when you adjust and tighten up the wand to this C, it's slightly skewed causing the wand to move "downhill" when it's positioned over the spindle. I adjusted as best I could with some washers and now it's much less, still there but much less. I couldn't adjust anymore because the entire assembly would impact the walls of the pocket which the assembly sits in. SMH what a mess. Ordered a new tonearm, but in the meantime, I can at least listen to the deck without pulling out my hair.
ordering a new tonearm really isn't an option, though.. Unless there are other tonearms that would be compatible without costing more than the turntable itself..
The YSA-1 or 2 are simply over the budget I'm willing to spend, especially for such old parts.
the YA39 tonearm is 700-1k and the YSA-1 is 1800-2300 USD before shipping and taxes..
And who knows whether they won't exhibit similar issues?!
From what I can tell, the YA39 and YSA-1 share the exact same tonearm base?
Some versions of the YSA-1 seem to rely on a different "pillar" for the vertical alignment (made from chrome/nickel plated stainless steel rather than aluminium?!), but that might be an aftermarket part, or an attempt to fix the issue I'm dealing with?!
And the rest looks to be identical..
To the point where it looks like you could simply take the straight tube and install it instead of the J-tube from the YA-39?!
so.. uh.. I'd be paying 1'000!!!!! USD for a straight aluminium tube with an angled headshell that cannot be replaced for a different aftermarket headshell?!
yeah.. I really don't see the appeal of the YSA-1
