Thanks for the replies and great info, I really appreciate it
I'll check some things as soon as I can and report back!
Yes, I believe so as I had read that it's important, I'll check my notes and maybe pull them to be sure!Did you MATCH Q1 & Q2 for hFe? These two are the input differential pair and if not matched your idle offset will NOT come down to spec. In this case with 2SA763's it adviseable to replace if you have a higher idle offset that is NOT adjustable to spec.
