Does anything sound better than those 15 watts?The one that popped up today is the one I got.
Working on the 666 starting last night! Will likely take me a while but I'm not keepin it unless it sounds better than a 222..
whoa whoa there's 18 of them watts I'll have you knowDoes anything sound better than those 15 watts?
What's your method of hooking up to the sub?You should hear the 222 bass level on a DCM double time sub. Dude, it’s amazing. We have an amazing sounding bedroom. I’ll remember it’s 18 walls. I promise.
Triple Deuce #2 for me. It came out of the original owner's "studio" in Des Moines, Iowa and now resides in Idaho. It's a little dusty but it looks to be a clean example otherwise and the blue film is still protecting the bezel. I'll crack it open and give it a test drive this weekend.
222 #1, which I acquired from our resident expert @bhairavi, is in the bedroom where it sees light duty as I really don't listen in there. It sounds very nice on the little Mordaunt-Short MS-25s. I'm going to give this one a spin on the big DP-105s and we shall see what those Klipsch horns (and ADS L810s) sound like . . .Man that's a lusty little machine. Makes me want to pick up some horn speakers and bask in that midrange richness!
I agree wholeheartedly with both propositions. I'll add that I have a recently acquired pair of JBL L96 in the living room and I've been hard-pressed to leave the room since hooking them up.As Mr EGR often points out - ADS + Sansui is a match made in heaven.
And thinking about it further, I'd say the specialty of each is that they make other equipment sound good - most amps sound great on an ADS, most speakers sound great driven by Sansui.
wonder what brand of cigarettes it tastes like..She's an OG. I think that layer of dust started forming in 1970.
Surprisingly, smoke free! Smells like vintage dust.wonder what brand of cigarettes it tastes like..
Yes, for sure. I'm happy to leave them be if there's nothing obvious going on. The other one is generally original, too. Very clean. @bhairavi only adjusted it and added banana jacks to the back before he offered it to me. It sounds great and I'm unlikely to touch it. Soundcheck on #2 forthcoming shortly. I got sidetracked with the 11000 today.If it’s not humming, hissing or buzzing run it as she is! Especially if you have another that’s been updated. I had an all original AU-101 that I found much guilty pleasure in listening too. There may be cozy SQ from yesteryear lurking under that layer of household dust.
If it’s not humming, hissing or buzzing run it as she is! . . . There may be cozy SQ from yesteryear lurking under that layer of household dust.
No such luck finding that cozy SQ. Initial soundcheck revealed some faint popping and crackling, no music. Following a basic control cleaning, soundcheck 2 yielded only very faint audio with the popping and crackling. Power supply voltage is good and it's good at the input of the F-10831 control amp tone board. Thereafter, we start losing significant voltage on the board. Bias readings at the emitter resistors are something like ~12.5mV and ~130mV. Center voltage at the outputs seems good, ~50V and ~25V across the pairs. It appears the power supply and the output stage are good but the in between needs work.Soundcheck on #2 forthcoming shortly.
