By the way, isn't the method of setting the bias somewhat flawed/asymmetric? When you set the L bias it's with no current running through the R channel, but when setting the R channel the L channel is active. Thoughts?
Well I couldn't leave it like this without some more investigation, specially because the output transistors on the L channel were running 1-2 degrees cooler. Sure enough, measuring across either of the 0.5 emitter resistors, I got ~5mV on the R and only ~2.3mV on the L! Adjusted both sides to ~5.5mV when warm.
All of which is to say... If you used the service manual procedure, you'd better recheck your L channel bias!
