OK. Maybe that’s .460V drop. If that's the case and 1 is open, then they would seem to test good. Next would be to pull the drivers, H713 and H714 and test them. Once you have tested the outputs, it's a long slog to pull, test, and put back transistors. Assuming there isn't a wiring problem, it seems something is blown on the amp. It could be transistor, a diode or a resistor. Less likely, it could be a cap.
You said earlier that if you put the right amp on the left side, it worked. Did I read that right?
