Set the frequency generator to 1 KHz and adjust amplitude to so that you read 4V peak on the scope across a 8 ohm non-inductive dummy load resistor on the 8 ohm speaker tap. That’s your base line measurement, I.e 0 dB.
Then without changing the amplitude, dial the frequency down. See what frequency it reaches 3.56 V peak amplitude. That will be 1 dB down relative to 1KHz.
Then without changing input amplitude dial the frequency up until again you read 3.56 V peak amplitude. Again that will be 1 db down relative to 1 KHz.
If you’re doing this open loop (no feedback or HF compensation applied) you should see the -1 dB frequency response points at something like 30 Hz to 10 KHz or so.
Then apply say 10 dB feedback and repeat the process. You should see frequency response bandwidth increase to something like 10 Hz to 30 KHz.
For power bandwidrh measurements you need to run the amp at 90% of max power into a large 8 ohm dummy load and repeat the measurements. A bit harder to do since the dummy load will heat up a lot faster so you need to be quick on the measurement and then remove signal and let the dummy load cool.
With 10 dB global feedback you should see power bandwidth 35 Hz to 20 KHz, with Hammond output iron.
