I'd say that someday, like some others, you may get an opportunity to actually HEAR a properly reproduced sounds of music by a high quality system and you will realize (although you may be too ashamed to admit it out loud) how poor the sound is you've been so admiring coming out of your computer system![]()
I love the word "sanctimonious". It should be used much more frequently in audio discussions.![]()
I agree, it will (no doubt) balance out the general humility of such discussions![]()
Except that at some point in your digital shuffle the ones and zeros need to be converted to an analog signal (by a Digital to Analog Converter = DAC) so this analog signal can be fed into your analog speakers, since digital speakers (although theoretically possible) are not yet available to reproduce any form of respectable sound quality level (unless you consider your computer speaker of sufficient quality to reproduce a respectable level of sound).
That is why there is so much debate between the analog world (where you don’t have to worry about converting one form of signal to another) and the digital world (where you do), but that is a hot topic covered in lots of other threads here, so we’ll just leave it at that![]()
It actually is like the difference between a TV dinner and dining at a fine restaurant. You can get a pretty good TV dinner in today's supermarket, and the taste of it may be quite surprisingly good..., until you compare it to fine cuisine prepared by a top chef...:scratch2:
You decide if there is a difference.
Regarding the OP..., fix the Mac
Ok, this is coming from someone who designed or co-designed a few outboard DACs, so a bit more than $0.01 worth i think...
1) Any SPDIF based digital output carries the data and the clock. The outboard DAC has to synch to this clock, which means that to an extent the jitter performance of the DAC is always dependant on the clock. While correct DATA transfer is possible even in a noisy environment with a distorted signal, badly matched impedances at the ends of a bad cable, the recovered clock characteristics which are ANALOG!!!! and a major variable in correct DA conversion, will be highly dependent on such circumstances.
2) Data carried in the SPDIF link has to be taken 'at face value' by the outboard DAC. Most if not all CDP/DVDPs do not implement any error correction signaling, at most it mutes the output when uncorrectable errors occur. In other words, correctale and maskable errors are interpreted by the DAC as genuine data, even though it might be corrupted.
3) Many DVDP's and most PCs internally re-sample 44.1kHz sampled CD audio to 48kHz. In particular PCs, unless equipped with special drivers, do this in a most unsatisfactory manner, losing up to 4 bits of resolution. Again, the DAC has no way of knowing the data has been mangled.
4) as far as the user goes, in most cases unless you have direct access to settings and parameters, you behave like an outboard DAC, trusting the data and clock to be 'perfect' when it may indeed not be so.
TOTL units are designed to minimize such influences - for sure, your mileage may vary as you may end up using a DAC (ether outboard box or internal) which is less susceptable to these problems, or have a decent mechanism which does not generate them on a mechanical basis - at least not until it gets mildly worn out - the fact remains, the issues were certainly adressed with care, to the best of ability at that point in technological advancement and price, in TOTL units. It shoul dbe noted that most of these issues are well known for the last 2 decades, and addressing them comes to engineering and skilled labour, which always is expensive. The expense in doing so has not changed greatly in the last 20 years. What has, is making chipsets that are less susceptible to them, in order to get acceptably performing units with less cost in engineering actual applications, while the cost of engineering the chip itself is divided down by virtue of mass production, since the same chips appear in many manufacturers actual units. Even though this makes the gap between cheap and expensive less, assuming the expensive is engineered properly (sadly, expense is no guarantee any more as lot of expense may go into marketing, which includes design), TOTL still means a lot.
:lmao::lmao::lmao::lmao:
The only thing I have to say about high-end, expensive players is that you better check out their guts pretty closely. Lexicon, for instance, buys Oppo's BDP-83 (which Oppo sells for $500), drops it in their box with Lexicon badges, and sells the exact same thing to unsuspecting buyers for $3500.
It's the same machine. What justifies that $3000 markup?
I take this more as an expression of just how good the Oppo machine is. I know my little Oppo 980HD universal disk player is freakin' excellent.
Lexicon, for instance, buys Oppo's BDP-83 (which Oppo sells for $500), drops it in their box with Lexicon badges, and sells the exact same thing to unsuspecting buyers for $3500..
For me the only time an analog audio signal leaves a piece of audio equipment is at the speaker wires. Up till then it is digital connections. If interference is going to happen then it has to get through the Audioquest speaker cables I use.
I don't understand what you're saying here. What, in your system, is converting the binary code from the computer files to the electrical signal being pumped into your speaker cables?
I mean, you have to have a DAC, a preamp, and an amp in that chain (or, if not a preamp, at least some kind of passive attenuator or potentiometer). All this may be inside your laptop or desktop, but it is in there nonetheless.
Unless I've really missed something in this whole world of audio reproduction.
Have I?
I have the HTPC hooked of to an Onkyo DS696 A/V receiver which drives a 5.0 speaker setup (2.0 for stereo). I have ripped most of my favorite CDs to the hard drive to a lossless format. HD movies are also on the hard drive. DVD/CD/BD reading issues are all but eliminated by doing this. I also use the HTPC to listen to FM radio stations since nearly all stations stream their their probramming over the Internet in Cd quality, or better.
The HTPC outputs a digital audio signal to the A/V receiver and its DSP is used to process the incoming digital signal. The DSP in the receiver handles signal decoding and then it passes it off to the DAC in the A/V receiver to feed the amps and the amps the speakers. Therefore, the only wires carrying an analog signal is the speaker wires.
Ok, I get it now. Your point was about external wires--the only ones carrying analog in your system are the speaker cables.
So implicit in that is that you believe the wires carrying the analog signal inside your receiver are better than having separates hooked up with interconnects.
Did I get that right?
Me, I prefer separates (to a point, obviously--I run an integrated amp). I think the flexibility allowed in using separates outweighs the down side to having the extra connections involved with interconnects. I know when it's time to upgrade my Rotel CDp, I'll just buy a better DAC and use the Rotel as a transport. That way I'll have something to run my FLACS into also (should I ever get into computer-based music storage)
I know it's a whole other conversation, but I have to wonder what if any concern there is with getting a perfect read when ripping CDs to FLAC (or similar). Cause if you get that wrong, you're stuck with it unless you do it over.
