Retrovert
Addicted Member
Japanese products lost their quality in the 1990s.
I don't know what components you're looking at, but I suggest you look at how competitive the marketplace is and the corresponding improvements in specifications.
PP film are lowest distortion but the AA-15 uses 10 µF for coupling so those need to be electrolytic. I would maybe bump them up to 22 or even 47 µF because it was not known at the time of this unit that electrolytics should be close to 10 times the value needed for the lowest frequency response in order to bring distortion down to the noise floor. Again, it may not make a lot of difference here given the limitations of the power amplifier.
Didn't think about a triac. My Harman Kardon Citation 24 uses a small transformer to pull a relay. Snubber capacitors across the line switch may have increased the life, but there are things that many of us didn't know 50 years ago.
I know why these caps. are small, they are polyester (aka Mylar). We audiophiles that design and build use polypropylene caps, which are larger but sound better.I was able to find a 10uf 50v WIMA MKS2B051001N00JS that is narrow and tall that will probably fit
BTW, electrolytic caps die more from non-use than expected hours of life. As sboa found, at 40 deg. C (typical temps.), caps are estimated to last for 70,000 hours. That's 8 years if used 24 hrs a day. So, i wouldn't worry too much. Its much ado about nothing, IMO.
Retro - I believe he is talking about replacing 10 uF coupling caps on the preamp board. Not main filter caps. So ripple won't really come into play.You omitted ripple current which will rapidly destroy power supply capacitors. It causes ohmic heating because of ESR which degrades or bakes out the electrolyte.
You might consider Vishay ASM series, one of the few axial lead caps still available.
The primary reason that capacitors fail in modern products like Flat Screens is because of the underlying design of the product and the fact that the unit is powered up constantly 24/7. In a 5 year period it will have accumulated about 44,000 hours of time waiting to be used.
Receivers, amplifiers and boom boxes that were made 40 years ago, have real on/off switches and spend a lot of their time turned off and powered down. I see many many units come through my shop that were made pre 1980 (with real on/off switches) and for most of them,it will be the very first repair. Models from the mid 1990's and newer (which are always in standby) will typically need repair after 10-12 years. - Chris
Some useful info indeed. You just need to separate fact from fantasy. For instance, recapping a flat screen TV will not affect the picture or tuning, even though the caps are cheap and will die prematurely in the power supply.useful info on this aging thread. decades ago i noticed how one simple 5v sense cap on an antec power supply could render it useless. oddly enough thats where they put the cheapest component too, how so very self-destructive of them.
more useful info:
https://superuser.com/questions/1295722/how-are-capacitor-lifespans-measured-in-hours
Absolutely true. Capacitors are easy to spot and easy to change, hence the obsession with them on audio forums. You don't need to understand anything about electronics to swap a cap and get the "fantastic transformation in sound quality" that someone on a forum claimed they had.Somehow capacitors have become an obsession in the audio world. There's far more to an amplifier or any other audio gear than just capacitors.
Seems that most will up the capacitance, not lower it. And with that comes other issues, like undue strain on power switch, power transformer and rectifiers.and yet, without capacitors (high capacity electrolytics) it would be difficult to discern music from rectifier ripple. the obsession between which high priced component will help squeeze out .01% better sound quality is a level of self inflicted insanity worthy of any dsm (diagnostic and statistical manual of mental disorders). especially since human hearing can be influenced by a common placebo effect, regardless of origin.
understanding something about electronics helps to avoid the following: change the standard 80v power filter cap with one rated for 25v just because the marketing said it was the best unobtainium in the universe.
i wonder what happens to amplifier thd when undersized caps are used (capacitance value)? something quite common in vintage gear due to the cost of early generation caps back then.
couple more capacitor links i bumped into:
http://www.audiotuning.de/index.html?2-01-blackgate-tech.html
https://www.humblehomemadehifi.com/Cap.html
