NIKKO 8085 Bias setting HELP!
johndoe10
Hi -- I have a Nikko 8085 stereo receiver that just had new output transistors installed for both channels. Does anyone know what the bias mV is supposed to be set to?
Thanks -- John
The 9095 manual says 30 mA (15 mV across .47 ohm resistor)
The 8080 says 20 to 30 mA (10 to 15 mV across .47 ohm resistor)
I think you will be fine with 20 mA, but I wouldn't go over 30.
Was the bias pot replaced. They are a known weakness in some of the receivers of that vintage....YMMV
Hi Steve -- I didn't replace them yet, I had to order new ones. One of the old pots had fallen apart at some point before I took possession of the unit, I found pieces of it floating around inside. I'll take your advice and set the bias for 20mA, just to be on the safe side.
Thanks -- John
